Anyone in Princeton / Hopewell Area
robocop80
Concord CA
Hello All,
I work in the Hopewell area and I like to bring my scanner to work. The only problem is I cant seem to locate any department worth listening too. Since I am very close to Trenton this would have been nice but the PD is encrypted so that is not an option. I am wondering if anyone is in this area, if so could you reccomend some stations that come in clear in this area. By the way I have a BCT 15 so no digital.
Thanks,
James
station32
Augusta Me
Hi most of the info is in the database but i will give you some.
154.430 Mercer F-1 Dispatch for most fire companys in the county
154.295 Mercer F-2 Used when the main response channel is used for another call
154.130 Hopewell Dispatch all hopwell ambulances and fire companys dispatched on it
154.175 Tac-1 washington hightstown and all the windsors and sometimes princton response channel
154.340 Tac-2 Hopewell, Ewing, Lawerence response channel
154.355 Tac-3 Hamilton response cahnnel
453.375 hopewell police
All PL's Are 103.5
460.575 Trenton fire simulcast of TRS no pl F-1, F-2
There are a couple frequincies i have at home that i can give to you
Do you work at bristol myers squib or merril lynch or something if you do there are some frequincies for that to so get back to me and i will get you them if you have any questions about mercer or hunterdon county i am an preatty much an expert about them since i am a firefighter in ewing.
robocop80
Concord CA
Station32,
Thanks for the response and the information. I think I am going to create a new system with all of the items you listed just for at work. I have the mercer county conventional freq set up for Hopewell Town, Princeton Township, Pennington Road Fire, Hamilton Township, Lifecom EMS and Lawrence Township. The Trenton Fire 1 and 2 on the TRS does not come in clear for me in my office but I still have it scanning since today is the first day I tried I will wait it out and see what I get. I work for Bristol-Myers Squibb on Pennington / Rocky Hill Rd. I dont have anything loaded for Hunterdon County because I didn't think I would be able to pick up anything from here but I will go in the database and get the Freq and give it a shot.
Thanks again for the info, I really appreciate the response.
James
station32
Augusta Me
BMS Paging 48.8000 B/M ?
BMS Old? 461.6125 M ?
BMS 462.2875 M ?
BMS 462.3875 M ?
BMS 462.4375 M ?
BMS 462.8625 M ?
BMS 462.9375 M ?
BMS 463.9625 M ?
BMS 464.0875 M ?
BMS 464.4625 M ?
BMS 464.5125 M ?
BMS 464.6125 M ?
BMS 464.7125 M ?
BMS 464.8375 M ?
BMS Old? 466.6125 M ?
BMS 467.2875 M ?
BMS 467.3875 M ?
BMS 467.4375 M ?
BMS 467.8625 M ?
BMS 467.9375 M ?
BMS Fire Brigade? 468.9625 M ?
BMS 469.0875 M ?
BMS 469.4625 M ?
BMS 469.5125 M ?
BMS 469.6125 M ?
BMS 469.7125 M ?
BMS 469.8375 M
try putting these in to
robbinsj2
Bridgewater, NJ
Those BMS channels look familiar. Also try out the repeaters for the Lawrence campus -- I think they may also cover the two other BMS sites in that area.
F-1 Emerg Svc Alerting 464.9750 R 136.5
F-# Security 464.4750 R d743
F-# Unknown 464.8500 R d315?
F-# Contractors 463.8750 R d125
F-5 Maintenance 464.7750 R d743
F-# Unknown 464.0750 R ?
Analog Paging 464.5750 R CSq
Hunterdon has some nice repeaters, you should receive them well from Hopewell. I take it you already have Princeton fire/EMS on 158.805/151.4. Princeton Borough PD tends to be more active than the Township PD, 460.2625/d565 & 470.9625/192.8. Some Trenton Fire talkgroups are multicast on 460.575/103.5 and that should come in better than the actual TRS.
I'd also try Somerset Fire-Hi on 154.310, Somerset pages with 100.0 but Mercer directly pages Montgomery #2 and Rocky Hill into Mercer County with PL=82.5. If you're more interested in action than proximity then you can add Somerset's trunked system -- most of it is analog and it should come in well too.
If you can fill-in PLs/DPLs and channel assignments for any of the unconfirmed BMS channels, I would appreciate it.
Jim
robocop80
Concord CA
Thanks for all of the info. I will add the BMS freq in as well and will work on the channel assignments in the next couple of days and will post when populated.
Thanks,
James
