Anyone know of a headset with a PTT toggle switch?
rapidcharger
The land of broken calculators.
I did not see a forum for radio accessories so pardon me if I missed it.
I'm looking for a headset with a PTT switch for handsfree operation while transmitting. VOX is not a good option due to the loud sudden noises that occur as well as pauses in the TX. So it needs to have a toggle switch whereby the operator presses the PTT and it remains open until they press the button again and it closes rather than a momentary type switch that we normally think of requiring the operator to press and hold the PTT until they are done transmitting.
The rest of the specs aren't as important. Looking for an accessory to use with kenwood portables but definitely open to using a different make and model if required to get this kind of headset.
Has anyone come across a headset or speaker mic that operates in this fashion?
ramal121
Lots and lots of watts
Calif Whine Country
The only thing I can think of are the Plantronics headsets dispatchers use. They have a locking PTT, however, they're not made to readily plug into a radio.
Headsets for Kenwoods are available from many different manufacturers. What I would do is see if any would make a custom headset interface for you. Might just as easy as changing the PTT switch from momentary to push on\off.
Setcom comes to mind as someone easy to work with as far as custom stuff.
Sent from my Nexus 7 using Tapatalk
cabletech
Puget Sound
Also, more information would be helpful.
Is this for portable, mobile? Do you want a industral standand over the head, dual reciever, signal reciever, or one of those super light weight telephone headsets.
What kind of enviorment are planing on uing it in?
You also say for Kenwood, what model?
I can tell you that any standard light weight headset will not normally have any kind of PTT.
Other wise I can more then likely fix up what ever you need as I do this type of stuff all the time.
