Anyone know what this is?
mfn002
Bryan, Texas
I found this in my radio station's storage building.
It has four frequencies:
384.6
346.7
582.1
524.8
cg
Connecticut
It is a radio usually used to alert volunteer firefighters of a call. The RF frequency appears faded otherwise someone could probably figure our who it was for. Guessing 60s or 70s vintage,
chris
ScanWI
MN & WI DB Admin
Wisconsin
Basically it is a 2-tone radio monitor. Like a pager it is set to a specific frequency and it can either be set to receive the tones or be opened up to receive all calls.
This one used a crystal unit to select the frequency. You can open it up and there will be a small aluminum canister with a frequency stamped on it. This is the monitor frequency.
Here is some more info,
Rig Pix - Regency Executive On-Call Monitoradio
N4MW Regency Monitors Page
mfn002
Bryan, Texas
Thanks. Unfortunately, my boss, who stuffed every last piece of electronic equipment used at the station in the last 40+ years in there, won't let me have it, even though it's cord has been cut and the telescoping antenna on top is broken.
mfn002
Bryan, Texas
What kind of reeds does it use and what do they look like? I'm thinking about pleading my case to my boss and, with luck, get it.
nd5y
Wichita Falls, TX
As far as I know all 1970s era monitors like that used tone reeds similar to what pagers used. Try googling the make and model number and "tone reed" or "tone filter". I don't know what they look like for that particular model. Probably a small metal can with the frequency or tone code labeled or stamped on it. It might look like some of the ones pictured here: G & G Communications
mfn002
Bryan, Texas
I'm going back over there next Wednesday to work on the station's transmitter, which is housed there. I might take that radio apart and see what kind of reeds/crystals are in it. As I said before, that place (the station's former studios up until 1990) is FULL of cool vintage equipment, including the station's original AM transmitter--a Collins SR20.
k3cfc
Silent Key
Beavertown Pa.
Regency Executive On-Call Monitoradio used for many many years to trigger a tornaodo siren for a Fire Department.
K3CFC
mfn002
Bryan, Texas
Oh. It can do that? I've been thinking about setting up a strobe alert for a weather radio because mine is in an area that isn't too visible. If I get it, I'll turn it into one.
W2NJS
Washington DC
If by chance you find a receive crystal in the unit that's marked something like, say, 45.250 mHz, just multiply that number by 3 and then add 10.7 and you'll have the frequency the radio is set to receive. As I recall, the Regency's used 10.7 mHz IF circuitry and this is the way you figure out the channel.
mfn002
Bryan, Texas
Would a scanner crystal work in there, or would I need to find some sort of special crystal?
Unfortunately, I can't find much info on this model.
ScanWI
MN & WI DB Admin
Wisconsin
You will need to open it up and see what type of Crystal it takes.
