Anyone Streaming Detroit PD/FD Audio Yet ?
rdale
Lansing, MI
The FireFeeds.net feed went down a few months ago, so there'd likely be some benefits from anyone choosing to fill that slot!
EC-7
Saginaw Co. Michigan
I was the person streaming the Detroit FD audio on FireFeeds.com, but I had some reception problems, and I got those fixed, but now i am having some high speed internet problems, but I am hoping to get it back up and running soon.
I honestly didnt really listen to Detroit FD, but since I have so many extra radios, I decided to be nice and host the feed.
Do they simulcast the FD audio on 154.310 still? Are they switched over to Digital yet? I only have 1 digital scanner, that I take everywhere with me, so I cant dedicate it to an audio feed now. If there still using the 154.310 freq, I'll try to get it back up and runnning soon. I didnt realise that many people really listened to it. I might also be able to get some other area going also, like Macomb County also.
SirScanalot
Adrian, Michigan
Det FD has switched over to the new digi simulcast system. To make matters worse, quite a few of us scanner users are having a problem decoding the signal. Its garbled, and sometimes non-existant. Not sure if its an issue with scanner firmware, but that may end up being the fix??
Chris
Microkid
Sterling Heights
If A Directional 5-Elem Yagi Doesnt Work....I Would Guess That Would Be The Fix You Mentioned....However If Someone South Of 6-mile gets reception, then we're back to A- Square reguarding power output of the tower, ETC........BACK TO PULLING OUT MY HAIR.
Ive been tryin to get my PRO-2096 on the air but I dont have a website to host it with. Im alwasy listening to it all day long while in the office. Anyone know where i can do a direct audio feed to a website?
EC-7
That s what I was thinking. I live in sterling Heights, (19Mile + Van Dyke) and I cant pick it up reliably, and I was even thinking about getting a yagi to point there, but I dont know how it will work out. I'm using a 6db verticle up 15' off the gound and have terrible reception most of the time.
If they were still on VHF, it would be no problem for me to host it, but until I can get a spare $500 digital scanner dropped into my lap, and they get thier tower issues solved, it looks like I wont be able to host it again. I might just end up hosting some other areas around here that are thill on conventional and put all my extra radios and computers back into service instead of colecting dust.
n8chb
fire departments
ffexpCP said:
Who do you have on the VHF fire side?
This is a list of fire department frequencys on the vhf radio.
It's not a scanner type radio and limited only to 20 memorys
I am not very good at selecting what others might want to hear and would welcome
any help or suggestions.
73,
Roger
n8chb@wideopenwest.com
153.890
153.770
153.830
154.070
154.130
154.145
154.190
154.220
154.265
154.280
154.295
154.340
154.355
154.430
155.265
155.280
155.325
155.370 intercity
155.760
156.800 coast guard
ffexpCP
wizard of odd
Michigan
Could you add Western Wayne County fire? 154.370 I see your in Canton, you should be able to pick it up.
I kept hearing Monroe county- what type of antenna setup do you have?
n8chb
Thanks,
looks like a gud one. Got 112 michigan locations on the fcc data base for that frequency.
The antenna I'm using for the fire feed is an old Ringo Ranger 2 meter antenna at 60 feet feed.
The digital radio is a bc796d uniden to an 18 element beam at 35 feet using a preamp
and fed with hardline.
Thanks again because I didn't hook the stuff up to listen to it.
I just did it for the fun of doing it.
73,
Roger
Alpha432
Downriver Area, Michigan
How are you are recieving Detroit so well?
What FD's and EMS do you have on that feed? I hear some other than Detroit on there? And maybe I missed this in the other posts, but how are you recieving Detroit so well??
n8chb said:
Please listen again,
I have two radio feeds running. One has Detroit Fire/EMS/Police plus
MSP freeway patrol on one stereo side and 100 mile vhf Fire coverage on the other side.
Roger N8CHB
http://www.wideopenwest.com/~n8chb/
n8chb
I gave a frequency list above and would like some help selecting the best ones to program.
If there is something you would like to hear pls let me know "n8chb@wideopenwest.com"
On the Detroit system. As I think most know it's a very complex pattern of very low transmitting antennas designed only to work in a specific area and the technicians did a great job getting it to do just that.
I have never been very good at explaining how to do stuff but I am working on writing a discription of my system on my home page but don't hold your breath waiting.
The 3 most important things about recieving radio signals are
1. antenna
2. antenna
3. antenna
73,
Roger
rdale
Lansing, MI
"As I think most know it's a very complex pattern of very low transmitting antennas designed only to work in a specific area and the technicians did a great job getting it to do just that."
True - but the question is, if you are getting it on your scanner just fine when nobody else is - what's the difference? Do you have a directional antenna pointed at one specific 701 tower?
