prcguy
It has some interesting features like being a single frequency repeater using two time slots and some other neat stuff. Anybody have one yet that can comment on how good it its?
However, my DMR output seems to be only half of what my analog output is for corresponding low, medium, high, and turbo power levels. Don't know if I need a special digital wattmeter to correctly measure? Same problem reported by some guy in Kansas the other day.
It's NOT a problem. DMR is TDMA, and since you're not a repeater, you're only TXing one timeslot. So the transmitter is only on 50% of the time, and a standard watt meter will average out the reading to 50% of peak. If your meter has it, use the PEP setting traditionally used for SSB.
You're wrong, and the meter readings prove it. It' only transmitting on one of two timeslots, so average power is 50% of what it is on analog FM.I believe that does not apply if you are using simplex. On simplex in DMR it will transmit on BOTH time slots. As far as measuring the output, you could always use analog.
Have not tried any repeater/crossband experiments yet
I'd love to have one but given that there's no remote separation kit for it... <sigh> Ah well, I don't yet another dual-band DMR radio (I have the CS800D), and certainly not another dual-band 2/70 analog radio (TYT-7800), nor yet another V and U mono-band radio (FT-857)
Unfortunately not. They chose to use a 20 wire ribbon cable to connect the head to the body! I guess they didn't want to spend a few dollars more for the mux circuitry which would allow for CAT5/6 cable.Looks like the head removes similar to their other models and I have an analog tri-band from Anytone that came with a separation kit even though it wasn't advertised. Even without a kit if the head comes off you should be able to remote it with a longer cable.
I just ordered an AnyTone AT-D578UV III so we'll see how this goes. The last thing I need in my life is another radio.
BTW, you can get it for $389 from "letsgetready" on fleabay with free shipping and 1yr US warranty.
Very interested in how your experimenting goes. Am also interested in whether the Part 90 model and the amateur model can both do the Single frequency repeater function. Being able to put up a repeater quickly without a duplexer or 2 antennas would be nice.
