The radiation angle of horizontally mounted antenna changes as the height above
ground changes. A very low mounted horizontal antenna will exhibit high angles of radiation
thus making it very useful for short haul contacts, but performs poorly for long haul contacts.
A vertical antenna is physically in the vertical position and think of it as a low dipole sitting
on end. The major pattern is at right angles to the vertical thus providing a low angle signal.
Most verticals are ground mounted and because of their size are difficult to elevate a great
distance from the ground.
If the vertical is ground mounted, it is necessary to provide a radial system to complete
the missing side of the vertical antenna. If your able to mount a vertical high off the ground,
it is still necessary to provide radials. That's why you see VHF/UHF verticals with radials.
Please don't get me wrong. There are many variations and variables that can cloud the
picture. You will find 1/2 wave and 5/8 wave verticals claiming that radials are not required.
The gentleman is asking about the Butternut HF9V which is basically a quarter wave antenna
and is normally mounted with the supplied mounting hardware at ground level and installing
a radial system supplied and installed by the end user. The antenna works well when it has
a good reasonable radial system installed.
If your unable to install the radials, or all the hard work is a turn off, then you would be
better off looking at something else.....
