Thanks Ghstwolf62, I'll give it a try and let you know..One thing, Do I Download to the scanner first or before.? Thanks again
If you have the information already downloaded from RR then do whatever you need to do editing wise in the software then when you are finished editing it to where you want everything go ahead and upload to the scanner itself.
If you haven't downloaded everything from RR then you can import each set of items into a scanner list from the import screen one at a time.
Ex:
Step 1- Select Import data from RR then go through selection process to get state, county and city you want.
Once you have that go from there.
Example:
Select ORION Omaha system
Select Omaha Police and place into scanlist one and import
Repeat Step 1
Once there select ORION system again only this time select Douglas county SO and scanlist 2
Repeat step 1 selecting ORION again and select Omaha Fire/EMS and Douglas County Fire/EMS and put into scanlist 3.\
Repeat step 1 and select ORION again selecting City/County Med channels and put in scanlist 4.
You import to the program each time and in the end you end up with 4 scanlists in this case all of the ORION system with each agency you want to monitor in it's own scan list or bank so to speak.
If you have already imported everything into the system then simply edit what you want to where you want it.
