Anysecu DM-960
Forts
Ontario, Canada
Followup.... I found one of these on eBay for $90 so I purchased it to compare against another low end DMR radio (Tyt MD-380) and it doesn't quite stack up. From what I can gather these are rebranded Kydera DM-880 radios however I wasn't able to get the Kydera CPS to even attempt to read the radio (their CPS makes Tytera's look award winning).
Pros:
- Looks like a Hytera PD78x knockoff
- uses cheap programming cable (Baofeng etc)
- Nice bright color screen
- battery life seems adequate
- DMR audio sounds very good
- Holds down loose papers on a windy day
Cons:
- Very very poor programming software
- Big screen but can only use 10 characters for aliases
- Scans VERY slow
- screen auto backlight dimmer doesn't work while scanning (always stays fully lit)
- Can't scan from analog channels (what?!)
- Can't set a channel as RX only
- Programming layout is very weird. Can have 32 channels in a zone but it has to be 16 analog and 16 digital. Then you need to press a programmed key to switch to/from analog to digital
- Very poor selectivity (for ex. transmitting on 154.6000 bleeds over onto 154.6200)
As expected you get what you pay for. If you wanted a cheap DMR radio to sit on your table to listen to your local PD/FD etc it works quite nicely. But if you want to scan multiple channels or really do anything else with it... look elsewhere. The Tytera is definitely the better radio at a very similar price point, and naturally doesn't hold a candle to a Hytera or Motorola.
Rating: 2.5/5
Edfox427
Syracuse NY
I just purchased one myself, and me being my dumb self. I thought I would be able to program it from the radio. Do you know what Baofeng cable it uses? (I have one for the UV-82) and do you know where I could find the programming software? (is it on a cd or internet)
w5rag
Also there should be a little CD with the radio. You'd think that they would provide a cable if they provide the software. If it isn't with yours, PM me and I'll send you a .ZIP file. There is a link on their website that looks like it should have software but it doesn't. Maybe it's my Chinese :)
Forts
Ontario, Canada
Mine didn't come with a cable or software... I used a cable I already had and got the software from the guy I bought it from. I'll upload it somewhere and post a link.
autovet
Hayden Idaho
Scan
Pros:
Cons:
- Scans VERY slow
Rating: 2.5/5
How did you get yours to scan. I created the scan lists and went into scan mode. it sais start scan then goes back to the regular mode. any tricks I missed? Please email brandon@centralprocessingcompany.com
