As stated above all Destin law enforcement and fire is provided by Okaloosa County. All analog. Ft. Walton is also analog. Conventional (non-trunking) freqs for both. Plus if your scanner will pick up the 225Mhz-399MHz range and you want to try military air comms then Destin is the place to be as Eglin AFB across the bay has numerous flight ops daily. All you need is a few app/dep freqs and you, like me, will end up with endless TAC comms, AR comms, etc. Yes, there is a lot of stuff to monitor in Destin, even the maritime freqs as well.
