Anytone Anytone 778uv getting allignment access via test mode?
VK5AC
Adelaide, South Australia
Hi al. Anytone 778uv seems a budget but reasonable capable radio.
I have a feeing the test mode should allow some allignment, ie s meter calibrations on different freq as well as output power fine tuning for different levels lo/mid/hi at differing freq? Any more clues from what I have found = which is a the model change to allow freq change (in test mode to allow wider coverage).
Earlier radios 578 appears to do this. looking at the method maybe i am missing something.
Appreciate any extra info on this. Just need finetuning a couple of the levels across 2m and 70cm.
measured by 2955.
thanks.
VK5AC
Still looking to minor Adjust deviation peak on vhf/uhf.
Test mode enabled by pwr down, hold func+F4 and power up/Enables CH39 to 43 to be selected. ON 43 hold ptt in and can then rotate selection knob to change the mode ie broadband TX all vhf and uhf frequencies. Release ptt to save. Power down and back on, radio comes on in new mode.
also CH-39-42 is selectable shows 39= RF FW version 1.10, 40 = CPU V1.11, 41 lcd V1.10, 42 = mode:02 amateur, 01 fixed, 03 broadband unlimited TX.
Still looking to get into the actual power and deviation adjustment settings.
Anyone???
AK9R
Staff member
Super Moderator
Central Indiana
Have you contacted the retailer, importer, or manufacturer?
VK5AC
It was an Ebay supplier and after locking the radio (accidently) they were no help at all. Th unlock method was located on Google but no such luck for the "factory adjustments" i am seeking.
thanks for the reply anyway.
