Stretchman
I just received my anytone 878 tonight, and made a basic codeplug for dmr. When I tried to put the database into the radio, it would not allow me to do anything except make private calls. I could not make contact with the repeater at all. Am I doing something wrong, or is it the database itself? I got contact 1, 12345678 and that was it. When I wrote the default back to the radio, then rewrote the plug without the ids, it worked fine.
IDK if there is something I actually have to do in order to get it to work.
Also, a quick heads up. When the radio comes stock, the encrypt key is programmed into one of the side keys. If you press it, it will turn on encryption, which is a big no on ham radio, and you have to go into the menu to shut it off.
