Anytone Anytone 878uv issue
firebell9137
I have the 878uv with current firmware and software. Using it as a fire dept scanner until i get my ham license. I went to go scan my area called Racine, wi scan and it's Rx'ing everything from the other zone which is Racine/Kenosha scan. All scan lists and zones are correct. I even went though the channels in that zone and the 3 channels that arent supposed to be scanned arent there but still scans them in scan mode. What should i do? Any help would be great.
Whiskey3JMC
DXpeditioner
40.0417240450727, -75.23614582932653
Did you download CPS? Detailed instructions on how to create scan lists & zone lists are contained within the zip file. Navigate to Programming Guides folder & open up AT-D868UV,D878UV Programming Guide.pdf contained within (PDF is too large to attach here). See STEP 4 - SCAN LIST then STEP 5 - ZONE LIST CREATION
chief21
Summer - Western NC; Winter - Tampa Bay FL
As suggested in the above post, suggest you read up on how the scan function works. The AnyTone radios do not scan zones... they only scan "scan lists", which you must create.
firebell9137
I did.
It was a corrupt codeplug is all. Reset it and started from scratch and now it works great. Thanks though
