Anytone Anytone 878UV Zone Issue
elspicymchaggis
Orange County, CA
Good Afternoon,
I was updating my radio programming (freqs, not FW or SW) and after it finished I restarted my radio and went to the new zone that I set up. I clicked one zone past it and saw the zone list "ZONE 35", which isn't a zone I have programmed, I only have zones 1-34 and they are all labeled specifically none are ZONE anything. I kept going and it went all the way to "ZONE 250". So apparently it programmed all available zone slots into the radio, even if those zone have no channels within them. It never used to do this and when you hit the end of the list, it would go back to the first zone.
Anyone have this issue and have a way to fix it? I have already tried uploading the programming again, and had the same results. However when i went to re-upload my programming, the radio basically did a hard reset to factory first. No idea why and just continued to re-upload. I did notice that all empty zones are showing a "0" in the number section, when I delete the "0" and just leave it blank, i get the same results as if i left the "0".
Thanks for any guidance,
Spicy
Hit_Factor
Saint Joseph, MI
Same thing happens when using the next button in the channels, if it comes upon a blank line it will add Channel 35, channel 36, and so on.
Just delete them and try not to create them accidentally.
Not sure how it happened in Zone, but it's probably similar.
And make sure you have the latest software and firmware: AnyTone 878/878 Plus CPS, Firmware, and Driver Downloads
