Anytone Anytone AT-578UV-III Pro Power On with ignition
N9JIG
Sheriff
Moderator
Far NW Valley
I am considering the Anytone AT-578UV-III Pro for 2M and 440 use in my vehicle to replace my Alinco DR-638. I already have an AT-D868UV portable and it works well.
The question I have is whether the 578 will power up with the ignition when I start my vehicle or will I have to turn it on every time I start the vehicle. Is there someone who has one that can advise?
Thanks!
dazey77
It will if you feed it from an ignition switched power feed! Looking at the photos of it, it only has two wires coming out of it, so it doesn't for example support a permanant 12V feed and a swtiched trigger. You would have to be either confident that the switched circuit you were putting it on was up to the job, or power it via a relay using the switched live as trigger.
TassieJay
Australia
Nope, it won't turn itself on when power is presented to it's input. It always needs human intervention to turn on, even if power was removed while last turned on, and then power reapplied.
There's no ignition sense facility at all.
