Hello,
1. If I transmit over my X200 Diamond Antenna to a Motorola DMR Radio on 2m - 3sec. the Audio is to listen and 3sec. failed. and so on.
2. Dual reception Sound quality compare with a Handheld Retavis RT82 and the AT578uv-Pro the RT82 is much clear then the not good AT578uv-Pro (worst quality).
3. If I receive i.e. 2/9 and on the 2nd Tuner a Simplex DMR - the Tuner will switch often to the 2/9 if a conversion is then there on 1/9 and no reception on the Simplex!
That mean if someone is talking on 1/9 there is no reception on the 2nd Tuner on Simplex direct - this is for a dual Transceiver useless!
I would like to receive the 2/9 on one tuner and on the 2nd tuner I would like receive my Home Frequency on 2m in DMR-Mode . But this is not possible and that mean that this Radio is useless. I thought that I can use it as two tuners but it is not so. :-(
Best Regards
weakbit
Best Regards
weakbit
