Anytone Anytone AT-D168UV: How setting a radio for PTT and 5 tone dtmf function ?
1enry1
hi, i have a new antone 168 handy .
in how mode in ANALOGUE Mode i set this handy for when press the PTT at the final of
my QSO the radio send a 5 TONE dtmf code ?
what is set in the MENU or the CPS into the radio ?
tnx for help me 73
chief21
Western NC (Summer); Tampa Bay FL (Winter)
This is a multi-step process that must be set in the CPS as I don't think all settings are available in the radio MENU. First, set up your 5-tone info under Analog / 5Tone. As a fail-safe, set up at least one encode code and be sure to make an entry for either Beginning of TX (BOT), End of TX (EOT), or both at the bottom of the page.. Once your settings are complete, you must go to the Channel Detail page of each and every channel you wish the tone to be used and specify Optional Signalling, 5Tone, and whether EOT, BOT or both. Be aware that these settings may be confusing, as some conflicting terms are used. Don't forget to reload the modified codeplug to the radio. Experiment a bit and you should be successful.
1enry1
chief21 GREAT!!!!
is a CHANNEL (single) programmation , correct ?
but this 5TONE encode .... trasmitt at the end of the qso , as a TONE sequence of dtmf or tone ?
is like the tone trasmission of a civil radio (like Motorola) ?
tnx 73
chief21
The 5Tone transmission is a very rapid sequence of five, single-frequency audio tones, while DTMF is a mix of two different audio frequencies sent simultaneously.
The frequency of the 5Tone tones depends on the reference number (0 through F) and the particular tone standard specified. The actual audio frequencies of whichever standard is selected are shown in the left side of the 5Tone configuration window.
Yes, certain 5Tone combinations are said to resemble Motorola MDC-1200 codes.
1enry1
tnx, but the CIVIL radio how trasmitt at the end of conversation a audio Tone or DTMF tone ?
1enry1
sorry .... i understand that in the "civil radio" not used the DTMF tone but the ZVEI tone ....
