Hoggorm
Hi,
I have a couple of questions regarding the AnyTone AT-D878UV that I'm considering.
1 - It appears to be several versions out. What are the main differences? What is the radio to get?
A few of the different versions I've seen:
AnyTone AT-D878UV VHF/UHF DMR Handheld WITH APRS - AnyTone AT-D878UV VHF/UHF DMR Handheld WITH APRS. Anytone at £169.95 | Ham Radio
-> not called AT- Anytone D878UV Plus (Bluetooth) / 3100 MAH - Anytone D878UV Plus (Bluetooth) / 3100 MAH Anytone at £199.95 | Ham Radio
AnyTone, AT-D878UV DMR Radio 136-174 & 400-480MHz w/GPS/BT
AnyTone, AT-D878UV DMR Radio 136-174 & 400-480MHz w/GPS/REC
2 - Can the radio be charged only when using the desk charger?
As I travel a lot it appears to be a hazzle to bring a large desk charger with me at all times... Is there no other way to charge?
Thank you.
Thank you.
