Anytone Anytone D578UV III firmware update issue
wa8pyr
Staff member
Lead Database Admin
Ohio
All,
I've got a D578UV III currently running v1.06N firmware. Trying to update the firmware to v1.10N (current version), but so far no joy. I've tried it on three different computers, following the instructions to the letter, and every time I click the "Firmware Update" selection in the Tools menu, absolutely nothing happens. The text instructions show in the pane at the bottom of the program window, but the pop-up where you select the firmware file and click the "Update" button never comes up.
Updated my D878UV III handheld on the same computer and it worked just fine, so I'm at a loss.
Anybody had this happen or heard of it happening, and a solution?
TassieJay
Australia
Yes, that happened to me a few versions ago. It resolved itself after a while, so not sure what happened.
To get around the problem, manually look for and run the firmware update sub-program, it's called QX_Firmware_Update.exe and lives in the Update folder of your CPS installation.
wa8pyr
Staff member
Lead Database Admin
Ohio
That worked; tech support didn't even come up with that one!
Thanks!
Tom WA8PYR
