AOR AR-DV1 first weekend evaluation
AA6IO
Cerritos, CA (LA County)
I have been using the AR-DV1 for several hours this weekend and am actually feeling more positive about this radio after further experience. First of all, I know I emphasized to Taka at AOR the importance of trunking, but seriously, I don't think we are going to get that with this radio. If you want that, use your Uniden/GRE/Whistler scanners.
That said, I can see that if the firmware updates can resolve some of the issues and the radio can do what it is supposed to do according to the brochure, it has real potential for many of us. I have to correct my initial impressions about sensitivity and receive function. I did quite a bit of HF/SW listening earlier today. Most of my amateur radio activity (not much recently) is CW. I'm an old DXer from the 1960s. So I go for SSB/CW stations, and when on HF, the utility stations.
My AR-DV1 seems quite sensitive across the HF spectrum. I have a 50 KW AM station (KFI) whose antenna is about 2 miles from my house. That pretty much overloads things with a dBm reading of about plus 2. That is more than one milliwatt right into all my receivers. With no filter, bam, the AR-DV1 is overloaded with my outside HF antennas. But with a high-pass filter in line, the 4 to 30 Mhz spectrum is quite sensitive. Pretty good CW, SSB reception, and strong SW broadcast reception. Even MW reception is not bad with the filter in place. That shows me that the radio itself is really sensitive on MW, prone to overload, but what else is new with a wide-band receiver. So all-in-all, OK.
Still not able to get search/scan working right on VHF/UHF. But when manually tune channels, not bad sensitivity. Quite good on Wx channels (3 of 7) with stock antenna, and with my outside antennas, 4 or 5 of 7 with reasonably good strength. Probably the same as my 536HP, but the sound quality sounds more like a receiver. Other VHF/UHF conventional channels sound pretty good. Airband and FM broadcast, OK.
The digital decode is quite good. I'm not looking for spectacular at this point, just reasonable decoding of all the modes it is supposed to decode. P25, NXDN, and DMR sound pretty good. Hear some motorboating on DMR, but we know that already and expect a firmware update.
So far you're probably asking "so what else is new Steve." Well I have been able find several new NXDN and a few DMR stations just manually searching with the AR-DV1. No decode info, but we know that too. But just being able to tune through the spectrum and pick up some new channels with a standalone radio, not dependent on a computer (as good as DSD+ is) is to me, a nice benefit of this radio.
My overall take at this early juncture is that this radio has some real potential for serious monitoring to detect new stuff. This will depend on 1) whether AOR can get firmware out to at least do what the radio is supposed to do, 2) if the radio can eventually give us some of the important P25, hopefully P25 P2, NXDN, and DMR parameters, and 3) if Gommert from Butel can develop some software for the radio (I mention Gommert because I know he is monitoring the AR-DV1 threads). Without computer control and some software to program this baby, it won't be much use. But if 1, 2, and 3 come to fruition, then I think the radio has potential.
With my experience today, I will probably keep the radio, and hopefully the firmware and software will be forthcoming. This radio will not replace your high end digital trunking scanners or a dedicated HF radio. But we all know that as well. No wide-band receiver will be ever able to replace higher end dedicated radios for HF vs VHF/UHF/800 (I know some might say the high end WinRadios can). But as a standalone radio from 100 Khz to 1300 Mhz, with all the modes, if AOR can get it working like it should, I thinkthe AR-DV1 has potential.
I will keep you posted on my experience.
dlwtrunked
I have had one since Tuesday. Still checking things out.
1. The aux output does an excellent job providing discriminator signal to PC audio input for Unitrunker monitoring of control channels--better than my ICOM R9500. Of course, like all Yaesu's, it itself does not do trunked. With the discriminator out and computer control via usb, this should be fixable to some extent by software.
2. The display data line apparently only displays D-Star data. I wish it would display similar for Yaesu mode and other modes.
3. Volume knob is not sensitive enough. It is digital and has to be turned too much to slightly change the volume.
4. As others have noted, to listen to DMR, get used to listening to digital noise between voice transmissions.
5. P25 voice decoding sounds better than anything else I have.
6. When in auto mode, regular FM is high pitched frequencies only and not near as good sounding as if in actual FM mode.
7. When bandwidth is adjusted for FM broadcast station, it does very well - even with my FM notch filter installed.
I have yet to try it on HF.
dlwtrunked
And also...
They really need to add a 2.5 kHz step-size as that is standard for some VHF systems so that the tuning know will find them rather than having to manually keyboard entry them.
XTS3000
That's one sexy looking receiver!
Does the keypad light up?
EricCottrell
Boston, Ma
And also...
Hello,
Several of my AOR Receivers have preset step sizes where you press the step button and turn the knob, but also allow the entering of a custom step size. The usual procedure is to press the key combination to select step, then enter the step using the keypad instead on turning the knob.
73 Eric
BamaScan
15 miles from Florida Line in Alabama
Yes. Some colors are not working and some are wrong.
The choices are:
1) Off - Works
2) Blue - Works
3) Red - Not real Bright looks off
4) Magenta - works Blueish
5) Green - Works
6) Cyan - works light blue
7) Yellow - Green (Needs to Be Fixed)
8) Orange - Green (Needs to be fixed)
I leave mine on Blue.
