trust_93
F5UOX
My vidéo in French sorry
https://www.youtube.com/watch?v=yKh_C-sp4tc
Hi All,
I would like to know how this radio handles receiving a system with Restricted Access (RAS) implemented. Does it receive RAS or block it?
For example the DSD/DSDPlus programs ignore the modified CRC packets that prevent squelch from opening so it receives it just fine. However Radios that implement full error checking such as Motorola, CS, and Tytera do not un-squelch RAS transmissions.
Thanks you,
Joe
I liked it as it showed me how to turn on the DMR slot feature.
Yes you can listen to Slot 1 or Slot 2 only. For me it's great that I can listen to Hospital Security on Slot 1 and not hear Maintenance on Slot 2.
Does anyone with the radio know the answer about if it can open squelch on a system with RAS enabled?
Hello everyone, I'm try the new release 1512A and all going fine when updated. BUT power off and up again...and the scan very slowly and big noise on somme channel. like if sql is always open the signal level meter flashing verry fast on eatch channel when in scan mode. I'm go back to the 1511B
Eric VE2MEL
Did you back up all your settings as described in section 5-2 of your manual? Is anyone else having this problem?
