oz1jua
Be aware that the new Memory management software can´t write CTCSS code to scanner.
Even when select the correct CTCSS it will not send it to scanner.
When manuel set this in scanner it will read it but if you send it to scanner it is gone.
I can se when sending to scanner it flash brite with a CTS under the display.
When setting the CTCSS on a channel it overwrite the name of the channel name.
There is lot of space under and I do not understand why this space is not use for this info.
The same goes for DMR channel it also use the channel name space to show color code ect.
But this is only when select Dig.Decode. If you do not whant to overwrite the chanel name
then set Dig.Decode unselected.
