Hi MacombMonitor and all,
AOR is an Icom knock-off and I suspect they do it with antennas as they do with Amateur tranceivers. I'll bet if you look deeper you'll find plenty of manufacturers which produce "second line" equipment at lower prices.
Funny, until now I've not heard about an AOR or Icom antenna, live and learn.
Of course they supply RG-58 coax, pretty much everybody does since that "gold plated" stuff is more expensive than the antenna. Frankly I'm surprised they supply anything, Amateur Radio antennas don't come with coax, they leave selection up to the individual acording to his needs.
Frankly I don't see what all this hoopla over that "special" coax is all about, I have compared electrical characteristics vs. price and found that Belden 9913 gives the best bang for the buck. Don't get ripped off by that mysterious legal disclaimer "(number) type", 9913 is a proprietary part number and ONLY Belden makes the real McCoy. Frankly it's one of a kind, technically it's semi-rigid air dielectric transmission line. For that reason it hates tight bends, the center conductor migrates out of position toward the outer conductor in too tight a radius worse than it does in solid or foam dielectric cable.
I wouldn't worry overmuch about the N connectors, they're a bit over-rated for receive only operation. They best come into play with high power VHF/UHF transmitting applications because of their constant impedance characteristics. They're also used with some Amateur Radio amplifiers but since you're not going to be pushing 1500W up the pipe I really wouldn't worry about it. Hmmm, I'll bet you're going to put a PL-259 and a Motorola adapter on the other end anyway like I have since I use my vertical for the scanner when I'm not on the air. (;->)
