APCO 16 vs 25
dstew67
Missouri
Can anyone point me in a direction to learn some simple facts and a basic background of APCO 16 and APCO 25?
Specifically, I'm interested in very "broad-stroke" answers to the following:
1. When was APCO Project 16 introduced?
2. When was APCO Project 25 introduced?
3. What are the basic differences between P16, P25 and P33 (not just with regards to trunking)? For example, what (basically) did each new "Project" update, and when?
Please, don't simply point me to APCO's site. I really want VERY basic answers to these, and some other questions. Can anyone help me out?
No, but here's a link to where the active committees publish technical documents - includes committee agendas for ongoing developments.
APIC
This is more of a snapshot of where they're at now than a timeline of where they've been.
Going from less-than perfect memory, I think P25 dates back to 1991. They chose the vocoder design in 1994.
P16 would be older than that.
-rick
N
N_Jay
Guest
http://www.apcointl.com/institute/apco33.htm
http://www.apcointl.org/frequency/project25/
http://www.apcointl.org/membership/past_projects.php
It amazes my that people don't put 30 seconds into looking before asking, but that soapbox aside.
Project 16 was started in the early 1980's
Project 25 was 1991, I think (as said in the other post)
I don't know about Project 33 (did you mean 34?)
As for the "differences" between the projects. Much more than the similarities.
They are not updates as much as completely different projects with completely different goals. There is some overlap.
mikegilbert
MHz so good
Los Angeles
Simple answer told by radios/systems in use:
APCO 16: Mostly 800mhz Smartnet/Smartzone trunking. I belive it requires:
1. a "fail-safe" fallback option. Motorola calls is failsoft.
2. Emergency Signalling
3. Different levels of system acess priority eg. Police/Fire radios before Sewer workers.
APCO 25: Same basics as 16, but updated.
1. P25 IMBE Digital Operation.
2. Latter versions are P25 CAI (common air interface) Basically means it's no,longer limited to Motorola and EF Johnson Brand radios.
3. It was designed to promote interoperability; which is pretty much B.S...
-Mike
N
N_Jay
Guest
-Mike
Like many overly simple answers, they are simply wrong.
However usually do a good job presenting the bias of the author.
This is basically right.
What is missing is the fact that the Project 16 was not a standard, but a functional recommendation.
Project 16 addresses trunking and only trunking.
In layman's terms, it provided a list of features that a trunked system needed to be acceptable for public safety use.
It did not specify how any of those functions were to be provided.
It was not aimed at inter-vendor compatibility in any way.
Most systems were at 800 MHz only because that is where most trunking is in general (and the only band that was trunked when it was written.
Here is where you make your first error.
P25 is nothing like Project 16. As I said earlier, there eis more different than the same.
P25 is a Standard, P16 is a recommendation
P25 is for both Trunking and Conventional, P16 is Trunking only
P25 tells "How" each feature must be implemented, P16 only says the feature has to be there.
P25 was developed from the start to be "all bands", P16 was developed for 800 MHz (only trunked band that existed)
This list can go on for a long time.
P25 CAI is IMBE Vocoder, C4FM/CQPSK medulation, and a specicified channel coding.
This is a common misunderstanding.
P25 allows for many system configurations. Motorola used P25 CAI on Smartnet trunked systems prior to having P25 trunked systems completed and to help system migrate.
These systems were not "earlier versions" of the standard.
One of the many goals was to promote interoperability and multi-vendor sourcing, and it is working quite well and getting better all the time.
