apco digital
pete8528
i recently bought a new scanner. I was wondering if i can hear anywhere in the state or just around the area.
Thanks for any and all help
INDY72
Indianapolis, IN
We need to know what kind of scanner you have: If its a Radio Shack PRO-96, or a Uniden Bearcat BC-296D/BC796D, then you should be able to listen to most digital systems with no issues. If its a BC250D/BC785D, then you will need the digital card. Just so you know: If your trying to monitor a EDACS Provoice system, you can hang up listening to any of the Provoice digital TG's, as there is not and will never be a scanner that can monitor provoice digital.
We also would need to know What State you are talking about?
INDY72
Indianapolis, IN
OK as long as you are not trying to hear a 9.6 KBPS (True APCO-25) System, or a EDACS Provoice System, you should be able to hear digital non encrypted voice on a digital system. If your trying to hear a 9.6 KBPS system, the BC250D does NOT support this format. The BC296D does, as well as the PRO-96.
