I have a YAESU FT-2D I am a fairly new ham and very new to APRS I have set everything in the APRS menu to what i believe to be correct based off of the YAESU manual and the "pro's" off youtube however. I don't appear to be sending my location out as it does not appear on aprs.fi i seem to be sending something out and i am receiving data packets but when i much reply to an incoming packet it just disappear's.
so i am probably just over complicating things but if anyone know the proper setting's to make this thing work. your help would be greatly appreciated. here is my whole menu and radio setup:
Raio is set to 144.39 on the B VFO side
1. APRS AF DUAL. (set to on)
2. NA
3. APRS FILTER. (default settings)
4. APRS MODEM. (set to 1200 bps)
5. APRS MSG FLASH (default)
6. APRS MSG GROUP (set to all)
7. NA
8. APRS MUTE ( set to on )
9. APRS POPUP ( default)
10. APRS RINGER (default)
11. APRS UNIT ( default)
12. APRS TX DELAY (set to 300ms)
13 BEACON INFO : ( AMBIGUITY - set to off
SPD/CSE - set to on
ALTITUDE - set to on )
14. BEACON INTERVAL ( set to 5min )
15. BEACON STATS TXT ( default )
16. BEACON TX ( set to Auto)
17. COM PORT SETTING ( set to off )
18. DIGI PATH : P3(FIXED) = WIDE1-1
WIDE2-1
19. GPS SETUP ( default)
20. GPS POWER ( set to on )
21. DEFAULT
22. DEFAULT
23. CALLSIGN : KE0JVH-7
24. MY POSITION: (gps auto)
25. MY SYMBOL ( human/person)
26. POSITION COMMENT ( in- service )
27. SMARTBEACONING (OFF)
28. Default
2. NA
7. NA
SPD/CSE - set to on
WIDE2-1
21. DEFAULT
22. DEFAULT
28. Default
