APT Portable Antenna
chrismol1
P25 TruCking!
I'm looking for nice plans for a portable or something not huge that I can use for NOAA Weather APT, maybe on a tripod or something. Just wondering if anyone came across something like this.
chrismol1
P25 TruCking!
Automatic Picture Transmission via weather satellites in the 137Mhz band
N1BHH
Jackson Square, East Weymouth, MA.
A turnstile antenna does just fine. I have sat outside with just my ham band walkie tuning the 137-138 range and heard plenty of signals on the OEM duck. You really don't need much. I have heard people mention using just a ground plane with good results.
http://www.wb8erj.com/turnstile_antenna.htm
http://www.west.net/~jay/turnstile.html
http://www.qslnet.de/member/pa1pj/turnstile.pdf
I used one for FM broadcast reception, that worked quite well. Try the above links and I'm sure you will have no problem with a turnstile.
jb872033
Cromwell CT
just started monitioring the WX sattelittes and i am using a hustler DCL with little problems, im sure i could do better with a helical but am satisfied with a discone roof mounted...what are you using at the moment if anything?
JB
chrismol1
P25 TruCking!
JB
Nothing, I'm just really looking for plans to build a really nice heliax. I want to know more about the different types of helical antennas for this kind of monitoring.
N1BHH
You really don't need much in the way of an antenna. The antennas I suggested in my previous post work, the QHA antenna suggested by another is also going to work. I like the initiative of building antennas, I do it when I can. Used to build ground planes for UHF and VHF out of ordinary hard drawn wire and SO-239's. As I mentioned previously, I have heard the satellites just by using the OEM duck on my walkie. A mag mount sitting on a metal shelf works, just about anything will work. It's always best to have as much capture area as possible, because doppler effect will cause signal losses when a null is rotated through. And one antenna placed out in the open with a clear sky view will do the trick.
