APX 1000 Programming
WQOQ867
Northwest Montana
Have a few APX 1000 radios im trying to get programmed and cant get the software to see the radio, It says unable to find device. Hook up my APX 6000 and it works right away.
Anything special to getting the APX 1000 to read?
I am on the latest version of CPS direct from Motorola.
Try another usb port for the 1000, see if it helps. Make sure the cps is seeing the proper usb port. It's possible it is drivers causing issue.
APX7500X2
NY/CT
What series cable do you have.......The older A series cable will read an APX6000 but not a APX4000...You need a B or C Series cable to do APX4000
