APX 4000 MDC Pre-Tone
lnicholls104
Nicholls
I am programming an APX 4000 with CPS 29. I have an MDC set but am trying to change the "Tone" the radio makes when you press the PTT button. I know there's 2 different "Tones" that it can be set to. A "Beep" then a "Beep" followed by a quick "Beep" burst at the end of the first beep. How to I go about changing the tone? I thought I had changed it but it is not changing the way the PTT beep is set to. Sorry for terrible explanation but hopefully someone can point me in where at on CPS I can change the PTT tone. TIA
jtech48
OVB
I believe the option you're talking about is the PTT sidetone and PTT short sidetone. There's also the tone on non secure TX. I am not all too familiar with the APX CPS but it could be a setting across all of the CPS software.
lnicholls104
Nicholls
I have found the "Sidetone" where the option is "PTT-ID Sidetone" and "PTT-ID Short Sidetone". I tried both of those options and its still adding the "Beep" burst after the initial beep. The option that I am looking for just has the quick "Beep" and doesn't have the second Beep after the first.
