APX 4000 QC-II Paging Decode and Alert
k4tdo
I am missing something simple in getting my APX 4000 to decode and Alert on QC-II tones.
I have a Conventional System set for QC-II with the correct tones in place.
I have a Conventional Personality set for the correct frequency and only my PAGING channel in it. With Signaling set to Quick-Call II with my Paging System selected.
I made a Zone with only this channel in it for testing. No scan or anything else.
This an an Analog one Repeater system.
It has to be something simple I'm missing.
Than ks Tim
k4tdo
Okay, I got this to work I had missed the Non Astro Call, Call Alert section.
One to glitch # 2.
I need this channel to not open for regular radio traffic. Only after paging tones are sent.
I have the Select Call and Call alert set to AND.
Thanks Tim
K2NEC
NA
Is this the issue you're having?
k4tdo
My Paging Channel is not in any Scan List nor do I have scan selected for this personality or Zone.
I an attempting to get this channel to stay Muted unless pager tones are sent from Dispatch.
Some of "OLD FOLKS" like to sleep at night.... LOL (unless we are called)
Tim
nhfirefighter
You will need to check off “in call user alert” and something to the effect of call alert decode. Then program a button or menu item for vmute. This will allow you to mute the channel unless proper tones are received.
Your other option is with the new APX feature you can also program QCII decode under MDC personality so you get the best of both worlds without having a separate QCII and MDC personalities if you use MDC.
k4tdo
The Voice Mute (VMUT) was the key. I had it all going but that.
Leave it to Motorola to make such a simple thing, Sooooooooooo Complicated.
I only have 75 of of these to do for 5 different departments.
Wish me luck.
wa8pyr
Technischer Guru
Staff member
Lead Database Admin
Ohio
Wish me luck.
Presumably everybody in your area uses the same basic codeplug, with certain zones available to each agency for their specific needs. Once you get a properly functioning codeplug to use as a "base" it's pretty simple; just do a "save as" from the base codeplug, alter the parts that are agency-specific (QC2 tones and the zones/channels which are specific to each agency), and you're home free.
