APX 4000 re-set
Markscan
New Jersey
Is there an easy way to reset an APX4000 to factory settings, that is to say, remove all programming so I can sell it? I have been trying to delete the program with little success.
clbsquared
Isle of Wight County
I'm not too familiar with APX CPS. But, if there are any model specific generic codeplugs like other CPS has, you should be able to write one to the radio by cloning it.
Sent from my HTC One A9 using Tapatalk
Always save the factory codeplug on a new radio. Always.
You can read the programming from the radio and then modify it. Take out everything you can. You'll need to leave something in there. I would often put in an RX only personality with a single frequency.
I had to surplus about 300 old Motorola 800MHz portables and mobiles and wiped every single one of them before they left my shop. Took a while, but didn't have to worry about someone causing issues with them.
mikewazowski
Staff member
Forums Manager
Oot and Aboot
Add a default zone, personality, scan list, trunking system, channel, etc, etc and then delete your information.
