APX 4500 and MIP5000
patt1345
Does anyone know if I can use a ITA2000A tone remote adapter with a APX 4500 on a MIP5000 console? I am trying to replace a XTL5000 consolette without having to purchase a APX consolette or a ton of other equipment. Thank you!
Tech21
Nope, the radio gets directly connected to the MIP 5000 gateway. You don't need a consolette, you just need an apx-7500 mobile to and the appropriate cables. Everything required is listed in the manual. You have to make sure it is a remote mount radio though.
billyfromhill
Tech21 is correct regarding a remote APX7500 and a digital gateway. This will give you IDs at the console and basically act as an O5 control head for the radio. Both the MIP5000 and the APX7500 are end of life however and I was told by my Motorola dealer that MIP5000 parts are not available to order as of last October. However...
It can be done but it is not "officially" supported. My MIP5000 deployment I manage has an APX consolette connected to a tone gateway which gives me 16 channels, but no IDs. I also have two APX 4500s connected to local gateways through the rear 26 pin accessory connector. I had to make my own custom cables up to interface the radio to the local gateways. When using a tone adapter you will interface the radio to the tone adapter using the rear accessory connector and then the adapter will connect to a tone gateway via wireline just like any other tone remote setup. You will not get channel steering with an APX 4500, so if you are replacing a XTL5000 consolette this may not work for you. You will be limited to a single channel/talkgroup. This will only get you audio, no IDs off of the APX 4500.
patt1345
we were able to take a UHF APX consolette, put a APX4500 800 in it, and by some miracle it worked. We don’t get IDs, but for a Solution that will get us by until our dispatch switch it will do.
billyfromhill
I don't suppose you get channel steering with the consolette with the 4500? To my knowledge the 4500 does not support SB9600 like the 7500 and 8500 can do so you can't channel steer with the digital gateway or in a consolette with TRC.
