APX 6000 quastion on channels/personalities per zone
brushfire21
NorCal - Napa Valley
Question regarding the channel selector switch on the APX 6000 radios. Can the channels per zone be increased beyond 16 channels and having the channel selector switch be continuous? I know of a few brands in the past that the mechanical stops could be removed and feature toggled in the programming software so that one could have additional channels beyond 16 per zone/group.
Thanks in advance and I did attempt todo some searching on this but nothing popped up that answered my question.
dryfb
America
Not an APX6000 or even an APX owner, but I do know the hard stops cannot be removed, although you can have more than 16 channels in a zone and assign a softkey to navigate channels above 16. If this isn't accurate please correct me.
Echo4Thirty
Houston, TX
Dryfb is correct, the only way to access channels higher than 16 in a zone is with the CHAN or CHUP/CHDN menus or equivalent buttons on the side.
Maximum channels per zone on an APX6000 is 625.
EDIT: 625 was determined by CPS 31 on an AN model 3 codeplug. Might be different for BNs or older CPS.
