APX 7000 UHF1/7-800 Continuous beep when pressing ptt
N8VDS
Flint,MI
When on a UHF analog freq radio will beep for about 5 seconds then beep once and quit while holding down the ptt button. Radio keys the repeater just fine. Also, it does not do this in direct mode. Only repeat.... Any ideas ?
Tnx
Randy
scfd4
Zip tie technician
PA
That’s the ptt sidetone, and I’m gonna assume you have mdc1200 enabled on the channel also.
Bick
Madera, CA
I had a similar problem (beep on PTT) on my xts5000. Finally found the cure. The radio was telling me that I was transmitting un-encrypted, or something to that effect. Found the flag in the CPS and programmed it out. May be a similar fix?
