APX 7000 Update FAIL
KevinC
Other
Super Moderator
Home
Quote"
I conclude that the statement about Motorola attacking previously hacked radios is without merit until such time as further information becomes available.
Word on the street is v18 does exactly that:
A cut-out from APX firmware version 18 readme, says
Abstract: Hosted Depot Updates
System Platforms Affected: All
Special Configurations: N/A
Description: This is a strategic initiative to address the security and robustness limitation found with the usage of older depot tools. Blocks the older stand alone depot tool from updating new firmware and Flashport.
The older firmware will still have the issue, and cannot be changed, so the fix will only apply to new firmware versions in this release and beyond.
The old depot tool key was being copied and replicated.
It doesn't "attack" any radio. Once you install FW 18 you will no longer be able to use standalone depot on that radio (until someone hacks the depot client :p).
MTS2000des
5B2_BEE00 Czar
Technically the boot loader was modified back on R17.00.01 HOST to accommodate audio instant recall. Writing to the bootloader with depot result in a bricked radio but not for the "enhancement" added to HOST 18 to thwart FUTURE unauthorized upgrades.
Upgrading to HOST18 won't remove features added by "aftermarket" means to exiting radios, but attempts to write to the radio after upgrading WILL result in a bricked radio that will have to go the depot under (presumably) flat rate or time and materials, provided they'll actually accept it. Ebay parts radios? Good luck with that.
allend
Long Beach, CA
So lets just say that you have an APX 8000 radio with all of the features built into the radio and the codeplug. You are not looking to keep Depot the radio and you have a valid CPS codeplug.
I guess upgrading to the latest 18 firmware is okay. I have 16.12 and just have not had the burning desire to upgrade the firmware. Everything seems fine at 16.12 with no issues.
dapaq2
Northwest Indiana
Can anyone tell me what I need to do to update the firmware on a Motorola APX7000XE? I am not finding instructions on how to go about doing this...
MTS2000des
5B2_BEE00 Czar
Download the firmware from MOL. Unzip the BBF. Open your CPS, click "refresh radio". The CPS will do the rest. Follow the instructions on the screen. Ribbon>Device>Flashport>Radio Software Refresh.
