APX 7000
rockriver556
While using the remote speaker microphone with 700/800 MHz antenna built in, does the radio transmit with the lapel mic antenna regardless of which PTT button is pressed? Does it TX with the lapel only when the lapel PTT is pressed?
N4DES
Retired 0598 Czar ÆS Ø
South FL
It transmits with both, but there is an option in CPS to select where the audio source will be selected from when a speaker mic is connected.
Project25_MASTR
Millennial Graying OBT Guy
Texas
He's not referring to the audio source but the physical antenna.
The real question is, what banding of apx7000 are we taking about? V/800 or U/800?
V/800 is easy to answer. Motorola discovered around 20 years ago that VHF PSM's impinge performance compared to a belt worn HT. As a result, VHF radios don't reroute RF to the PSM. So with a 7000, VHF utilizes the radio's antenna while 800 utilizes the PSM antenna.
rockriver556
It is a VHF/800. So while on 800 band if I TX using the PTT on the RSM it will utilize the RSM antenna? What about when I key the PTT button on the radio itself - will it then use the HT antenna? Is the RSM antenna disabled when operating in VHF band, defaulting to the HT antenna regardless of which PTT button is pushed? I guess my biggest question is if the HT antenna gets bypassed anytime the RSM with built in antenna is attached to the radio?
N4DES
South FL
Ahhh yes so he did. My bad. Well I guess the additional info can't hurt. :)
Project25_MASTR
Texas
If the RSM is connected it will bypass and use the RSM antenna for 800 MHz regardless of the PTT used. Audio may not be setup that way. VHF will always use the portables antenna regardless of the PTT used.
