APX-7500 07 Control button assignments
vittles04
Premium Member
Michigan
Hello,
I have an APX-7500 and I have the 07 head remote mounted. Everything is programmed perfectly and work perfectly except the rotating toggle switch. I will update this thread with the CPS version and firmware version tonight as I thought I had the CPS on this computer.
The initial issue is if you into CPS> Radio Ergonomics > O7 Control you can assign the rotating knob for a primary and secondary functions just as well as some of the other buttons. I can select the primary function but the secondary function is grayed out "un-changeable." I would like to have this function as follows PRIMARY: VOLUME SECONDARY CHANNEL (I assume the action performed is depressing the knob which will bring up the current zone channel listing which when selected and depressed again will change the channel in the current zone)
Another question is the head has a blue dot on the front which I assume means bluetooth am I correct?
Thanks in advance and if any other technical information is needed please advise and I will make sure to include that tonight.
Asmitty0010
New Hampshire
i had the exact same issue.
Heres the fix: In APX CPS, set VIEW to Expert Mode. Radio Ergo Wide - Controls - Control Head O7: Multi-Function Knob - MFK Behavior = Rotary
gesucks
Our Nation's capitol
Yes the head has the same Bluetooth as the APX portables. NO you can not use it. Almost 3 years and the refuse to turn on access to the Bluetooth in both the O2 and O7 heads.
vittles04
Premium Member
Michigan
Thanks !!! I am terrified for when I get the siren and lights hooked up...learning curve !!!!
vittles04
Premium Member
Michigan
well that is goofy. There is logic in Schaumberg.... searching searching searching, bonk
