apx-7500 consolette
Tech21
APX-7500 consolette refuses to switch sites on a statewide trunked system. The codeplug is programmed with 20 sites in the site list, no preferred site list is programmed. Control Channels are good and verified with a portable that other sites are able to be seen. There is no site lock enabled. The consolette is running cps 21.40.00/fw 21.43.00. The site it's stuck on is almost 40 miles away so that kind of rules out the antenna. The 2 nearest sites are 10 and 15 miles. Any suggestions?
Tech21
Yes, talkgroups are open in the county that owns them and all bordering counties.
Tech21
Nevermind, got it figured out. Combiner had a bad pre-amp which dropped put the rssi in the dirt for all other sites. Removed pre-amp, consolotte associated with several sites.
