APX APX 8000 and P25 Hot Spot
My Zumspot can do DTAR, DMR, YSF, and P25. Does anyone have resources to help me learn how to program the APX8000 for this? I'm not familiar with the digital modes yet. I have a couple of P25 repeaters in my codeplug, but I'm not sure they are programmed right since they aren't close enough for me to hit with the portable.
Echo4Thirty
Program the conventional channel in the APX to match the frequency and NAC you set your hotspot for. Create a conventional Talkgroup list in CPS and assign it in the personality along with the TGRP menu and set it as 'selectable' not 'strapped'. You select what TG you want to send to your hotspot via the radios menu. I would recommend running the radio in low power.
Ok, I follow but then am quickly lost.
On my hotspot, I have the P25 config set to:
  • Startup Host: 10100 - m1geo.com (I have no idea what this is)
  • P25 NAC: 293
In CPS I have an empty List 1 in ASTRO Talkgroup List. Where do the Talkgroup IDs come from? I got the repeater frequencies and NAC code from repeaterbook, I don't see any info on Talkgroups.
Thanks for the reply.
