Motorola Solutions Technical Notification (MTN)
TITLE: APX8000 and APX6000BN radios cannot access a Type II Trunking site resulting in retries.
TECHNOLOGY: ASTRO Subscriber
SYMPTOMS:
In certain locations, the APX8000 or APX6000BN radio may not be able to reliably access a Type II Trunking site.
This behavior can lead to a delayed connection or a failure to connect.
MODELS / SYSTEM RELEASES / KITS / DATECODES AFFECTED:
APX radios using R15.00.00 firmware and higher
Only applies to Type II Trunked system
Only applies to APX8000 and APX6000BN models
Factory started shipping R15.00.00 – Nov. 2, 2016
SEVERITY RECOMMENDATION:
_X*_ Medium - Perform at next scheduled maintenance
* Only if the using the affected configuration.
ROOT CAUSE / DEFINITIVE TEST:
Firmware defect
WORKAROUNDS AND CORRECTIVE ACTIONS:
NA
RESOLUTIONS AND REPAIR PROCEDURES:
Any unit shipped after February 13, 2017 has the NEW ISW Window Adjust value
1. Attach USB programming cable to the APX8000 or APX6000BN, open CPS and perform a cpg read by selecting "Read a
Radio."
2. In the opened cpg, navigate to Trunking Configuration->Trunking Wide. The last field at the bottom of the Trunking Wide Page is
the ISW Window Adjustment Setting. Verify it is defaulted to the wrong value of FEA8
3. Modify the ISW Window Adjustment hex value, the second field on the right, from FEA8 to the correct value listed below:
APX8000 - FE9E
APX6000BN - FEA0
4. Write cpg back in radio by selecting and clicking Device->Write Device, with the default Communication Method:
USB Cable
5. To verify the cpg has been written properly and contains the correct value, repeat steps 1-2, and verify the ISW
Window Adjustment value is matches the value in Step 3.
See attached pdf.
Marshall KE4ZNR
SYMPTOMS:
Firmware defect
NA
Radio."
APX8000 - FE9E
APX6000BN - FEA0
USB Cable
See attached pdf.
Marshall KE4ZNR
