APX 8000 Scan List
rustyjw
I programmed an APX8000. I entered channels into the scan list. One particular channel is in the scan list, however, when you turn the radio to that channel. the radio does not scan. When the radio is on the other channels, it scans fine.
Did I miss a check box or something?
buddrousa
NW Tenn
By chance is the channel that does not scan a Trunking Control Channel?
mikewazowski
Staff member
Central Ontario
The personality for the channel that won't scan probably doesn't have a scan list assigned.
Just entering a channel into a scan list only means it's part of that scan list. It has nothing to do with what's scanned when sitting on that channel.
rustyjw
I checked the personality for the channel. Under FEATURES, scan listed "None". I changed it to Scan List 1. I'll update the programming of the radio and see if that fixes the problem.
on another note, can the APX have multiple scan lists?
riveter
MD
You can have about as many scanlists as you want, with members distributed however you want, but only one scanlist per personality (though you can have multiple channels/frequencies/takgroups defined in that personality).
Scanlist members and scanlist access are in no way related: e.g. a personality does not have to have any scanlist members in it to scan a particular scanlist.
For instance, a personality with only talkgroup 119 could scan a scanlist with only talkgroups 102 and 115.
Hope that clarifies.
