Got the link working, but it still doesn't answer my question or I am mis reading Is there a way to enable the functionality of modifying the scan list from the front screen. when I hit the scanl button it brings up the scan list. even when I take it out of multisystem scan and put it to the trunking channels only, it still does not allow me to edit the list. It will bring the Scan list up but no edit functionality will show which does on my 4000's!!
There is a good chance you might not be able to edit the scan list from the radio keypad if it is not configured as "Operator Select" in the programming software. What other folks describe above requires you have access to APX CPS and an APX programming cable.
If you have both of the above then you need to make sure the following things match up:
1) In "Scan Configuration" the "Priority Assignment" make sure the choices have "Operator Select" as choices. Then make sure you have blank "Unassigned" scan list members. Folks forget about this but if you only give yourself 5 scan list members then you will only be able to select a max of 5 scan list channels. If you give yourself 20 scan list members but only use 10 then you still have 10 blank scan list members to use.
2) In the Personalities (Trunked or conventional) in the "Features" section make sure the scan list from #1 is selected. THIS IS IMPORTANT. If you do not associate scan lists with their respective personality (again trunked or conventional) then you won't be able to add channels/talkgroups from the personalities to a scanlist.
Then again if you don't have CPS or a programming cable take your radio to an authorized MSS and have them do the above for you.
Marshall KE4ZNR
