APX 8000 w/digital tone signaling
dustinw251
Franklinton, LA
Correct me if I am wrong but the APX Series on digital trunking will only Decode the Digital QCII? I have the APX8000xe! Or will it by chance Encode Also? I been trying to figure it out, I have went in and setup my tones and when I go to assign the QCII to the Menu it will not come up after writing back to the radio. The Option was specifically ordered when the radio was purchased. If it will encode can someone assist me with the setup please?
KE4ZNR
Radio Geek
You can both encode and decode in the APX line as long as you have the following option in the radio:
DIGITAL TONE SIGNALING
Reduce response time to an incident by instantly alerting
large groups of on-duty and
off-duty responders over their APX radio.
•Commonly used in Fire Rescue to alert first responders
to an incident by broadcasting a series of distinct, rec-
ognizable tones followed by a voice transmission from
dispatch.
• This allows an entire fire department to be simultane-
ously alerted to an emergency
situation, as opposed to unit to unit dispatch (Call Alert)
which takes longer.
• It allows the responder to keep their radios in a quiet/
silent mode until a critical alarm is raised.
• This feature works on P25 Conventional or Trunked
systems, providing digital quick call II operation that is
identical in operation as the legacy analog version.
•By 7.15.5, the feature will support encode from an APX
portable or mobile with a DTMF keypad.
Portables: QA09000
Mobiles: QA09000
Dependencies: P25 operation (Digital CAI)
I can send tones out on both my 7000 & 7000XE on both conventional and on Trunked.
The help menu in APX CPS should clarify more and if I get some time tomorrow I will try to record a video showing my APXs sending and receiving QCII tones.
Marshall KE4ZNR
Sent from my Pixel XL using Tapatalk
dustinw251
Franklinton, LA
I got ya. Well the help file was saying note: apx series can only decode qcii in trunking. But why cant I get the option to show up in the menu. And when i got to my call/page the tone signaling list is greyed out. The purchased flashcode shows the option as yes but the used flashcode it shows no
dustinw251
Franklinton, LA
Could that be the problem that the call/page under personalitys need to be enabled but may be locked by the lady that programmed it on our system. She got it setup on the 700system but left the rest to me.
jgau405
Question for you all. I have tone signaling set up on my APX4000. I am able to encode on conventional without a problem but it won't decode. Anyone know what settings I need to have for it to decode? Thank you!
