APX 800XE TDMA ENABLED
wgbecks
NE Wisconsin
If the radio has TDMA in the flash code is that automatically enabled, if not, how is it enabled. Is it in the programming menu software tree?
Check the "Phase 2 Voice Capable" option in the ASTRO 25 section of your Trunking System. Keep in mind that you'll need to
define both FDMA and TDMA Channel Types matching the band plan for your system into the ASTRO 25 Channel ID as well.
