Apx 8500
spidermo
othello wa
So I have an apx 8500 vhf/800mhz unit with a multi band antenna. Do i need a multiplexer and second antenna to split signals? Installer advised i might need it.
spidermo
othello wa
Thanks for the responses: System installer used Motorola AN000131A01 All-Band VHF, UHF, 700/800 MHz Mobile Antenna Kit when adding APX 8500 system. I got a surprise, ' I think you need a multiplexer and VHF band antenna also. I figured they were my system expert.
RocketNJ
Pequannock, NJ
I can confirm what KB2ZTX said, the all band antenna included with the 8500 works without any addition diplexers. It also uses a special coax and connector, not the mini PL.
spidermo
othello wa
Right, the system provider, did add the 'press connect' end piece to coax. I just have to complete wiring DC power and mount unit prior to it being programmed. Thank you all for the information.
RocketNJ
Pequannock, NJ
The coax that comes with the all band Moto antenna has the connector already installed and is lower loss than the standard RG-58u
