APX Audio Profiles for Receive
lion2479
APX 900- Have radio profile set to loud. The settings are great on receive much more audio out of the speaker then the standard setting. However; I would like the audio from the internal speaker and or remote mic to come out with more bass and tone down the treble side. Can anyone suggest good "receive" audio settings this would be only for a system using digital, no analog? See my settings currently in use attached. Suggestions welcome for receiving audio. (Not a very loud environment I'm working in other then on an ambulance or the side of a highway). Thanks fellows!!!
hakwye8518
Town of Islip, NY
1st make sure your viewing the codeplug in expert mode. Next under your radio profiles loud audio scroll down to speaker / rx settings, under audio equalization change group setting to custom for both radio and accessory. Then modify digital low frequency band for both radio and accessory.
APX8000
Sarcastic Member
AES-256 secured
The problem I've found with changing the RX audio settings are unless every subscriber on the system is the same manufacturer using the same TX audio setting, its not going to work. For example, I've tweaked my TX audio per system on my APX's which sounds great on the RX side for my ears compared to default Motorola settings, just crisps it up in my opinion. But then someone will blast me out of the room or a console will be set with gain jacked all up or a dispatcher is using a headset and whisper talks. Just my .02
GTR8000
Reverted to False Posting Guy
BEE00
Yeah, even then there is no guarantee of success. APX portable sounds different than an APX mobile even with the same TX EQ parameters due to difference in microphones, and the APX consolette normally sounds awful due to the desk mic having way too much gain and/or no one bothering to tweak the audio if it's interfaced with a console.
tl;dr It's often a futile effort
joedisp
Union
Give this a try, Audio Settings, Audio Equalization, Group Setting, Radio & Accessory, Select XTS as your setting. The audio will sound much like it did on the XTS series of radios.
APX8000
Sarcastic Member
AES-256 secured
@GTR8000 and I tested a few different settings a while back...I settled on XTS Audio Equalization for digital and Custom for analog with the same Low Frequency Band setting as -3 and the "High Frequency Band" changing from from 6 to 3.
GTR8000
BEE00
And actually the XTS setting is available in the default Full view, don't even need Expert (although Expert will display more parameters)
GTR8000
BEE00
Good catch, I had completely forgotten about that parameter being a prerequisite for getting into the advanced audio options.
