APX APX CPS Installation?
mikey224
Installing CPS and I get this screen followed by three others for files to be installed, could anybody help me set this up correctly to get the CPS installed...
Thanks!!
mikey224
I tried to download that but Microsoft says I have a new version already installed......
mikey224
Was able to get the CPS installed by strictly running the CPS file, so now I can’t get the cable to read the radio and when checking the cable driver the PC cannot find the driver. I get an audible tone from the PC speakers when connecting and disconnecting the cable to the PC though any suggestions?
K2NEC
Try this:
-Power off radio
-Connect cable to radio
-Connect cable to PC
-Power radio
Did you set the port in the program the radio cable is connected to the computer?
Doesn't need to. It should automatically recognize it
GTR8000
NYS Database Guy
BEE00
Port? APX radios connect via Ethernet over USB, not a COM port.
Download the APX USB drivers from MOL, then try again.
mikey224
No, I didn't where is that done? Also in my device manager the "Motorola APX Radio" says that the Driver needs to be installed. I cant figure this out, I thought the driver would be in a file in the CPS somewhere...
GTR8000
NYS Database Guy
BEE00
Would you be so kind to send a link for that driver download?
The APX USB driver install software is in the same folder on MOL as the APX CPS. Log back into your MOL account and look for Motorola APX USB Setup at the bottom of the APX Family Portables and Mobiles page.
mikey224
Thank you for all the help Gentleman, It was a PC issue not allowing me to install an unsigned driver. I was able to get it up and running.
