APX CPS Top Level Drag/Drop locking up
dgruver911
Newton, KS
Anyone else noticed in the last few updates to the APX CPS versions 20.x, and 21.x that doing a top level drag and drop to program radios (different model number, features, etc) that the CPS gets hung up forever and you have to task manager/end task and restart the CPS to accomplish the drag/drop programming, then if you attach a new radio start the whole sequence over again?
PACNWDude
Yes, issues with current R21.00.01 version here, as you described. Using Panasonic CF-53 and Windows 10. If it isn't Windows issues, it is Motorola, and any combination of both. Trbo CPS is also a "work in progress" at this time as well. R18 for APX and R16 (Build 827) for Trbo seem to be the last stable versions as of today and my own experience.
Tech21
Success! CPS 21.20 with FW 21.03. FW 21.23 (newest) won't go.
newest version of CPS is 21.40.00 and FW is 21.23.00. Update to newest CPS and that will fix the firmware "issue" you are having.
You have to be running the most current version of CPS for the most current version of FW to be installed on the radio.
GmanX
I dont know why but CF31 and APX software is so slow. Other computers work much faster with the software
jthorpe
Export the codeplug, then import it in the one you want. Remove errors, and golden.
dgruver911
Newton, KS
Well that makes sense. What doesn't is why they released the 21.23 firmware well before the 21.40 CPS. I downloaded the 21.23 FW and 21.20 CPS the same day because that's all there was on MOL. Didn't see 21.40 until after your post.
