APX Display
Medic10mda
Ø Pittsburgh, PA
Pittsburgh, PA
Would anyone know why E4F2 should show up as a prefix to a radio ID on a P25 conventional channel? For example incoming radio ID is 12345, the APX display shows: "E4F212345"
K2NEC
It could be that the radio is set to show "E4F" instead of "ID:"
For example, I know a place that has the radio ID in front of the P25 ID when it shows the ID. Like the radio ID is 205, so when an ID comes up it shows "205 12345"
N4DES
Retired 0598 Czar ÆS Ø
South FL
They could have it programmed in as the Soft ID.
Medic10mda
Ø Pittsburgh, PA
Pittsburgh, PA
Any idea what the feature is called? cannot locate it.
tyler3328
In your APX CPS go to
Radio Ergonomics > Controls > Display > ID Display
There you will see what the Prefix is for UID
If you do not locate the Prefix you are seeing there then
Call List Config > Unified Call List
See if the prefix is attached to any Alias
Medic10mda
Ø Pittsburgh, PA
Pittsburgh, PA
FIXED! Thank you.
tyler3328
FIXED! Thank you.
Awesome.
BUT..... Remember many agencies weather it be as small as a Single Agency or as large as a State Coordinated. Be sure that the Sys Admin did not have the Prefixes in there to match their Unit ID Map. They may have had the prefix or Alias programmed in such a way to correspond with their UID Map and changing that may make it hard for asset tracking or dispatch
K2NEC
Awesome.
Not sure what the prefix has to do with tracking since radio tracking should be done via serial number anyway. The prefix is strictly how it looks on the radio when an ID shows up. But I agree that unless it's your personal radio I wouldn't really mess with the radio. It's a nice way to get the codeplug locked.
tyler3328
I agreed it should be done via serial. But I’m referring to when the radio is TXing ID to other units. When the is shows up on other radios it should be according to their UID plan. I do understand that it is on his device and it will show differently but if it’s an agency radio and someone uses it they may be confused with the ID display
It’s hard for me to explain
K2NEC
Ok I think I know what you are talking about. OP shouldn't be changing the radio ID in the personalty but that's not the same as changing the prefix from "E4F2".
Medic10mda
Ø Pittsburgh, PA
Pittsburgh, PA
It was only the prefix I wanted to eliminate in personal radio. Thank You for the above info.
