APX DTMF
HD-Song
May I ask the experts in the forum. I have an APX 8000 walkie talkie. I want to use APX to remotely control my other repeater, which requires sending a series of DTMF codes. Currently, I can use the numeric keypad on APX to press one number key at a time, but I find it cumbersome. Can I set the DTMF code I want to send in the APX walkie talkie through CPS software? If possible, which function option in CPS software can input these codes?
Thank you very much.
HD-Song
Yes, if your model supports it, phone dialing is programmable. You can create call lists and autodial from them.
Use the CPS help function.
Thank you very much for your help! I am currently confused about the application settings of APX8000 walkie talkie in CPS software. I couldn't find the phone dialing function you mentioned in the CPS control function directory. Can you tell me the specific path? thank!
