APX GMRS FRS CODEPLUG
lookforthe1
does anyone have a codeplug loaded with the gmrs and frs frequencies that they are willing to share?
tyia
GTR8000
NY/NJ Database Guy
BEE00
Not to be a jerk, but in the 5 hours between creating this thread and replying a few minutes ago, you could've easily entered those frequencies into CPS and had a working codeplug. I get that it's easier to ask someone for a codeplug they already created, but that person put the effort in themselves, so why couldn't you do the same? The best way to learn and be proficient is to put the work in yourself.
vagrant
ker-muhj-uhn
California
I don't think you are a jerk and you have a good point, but there is the world outside ourselves to consider. Things can happen to people and they may no longer be physically able, and or competent to perform the actions needed to program that, or any radio. Disclosing a disability may be something they want to avoid as well, although most people happily help when knowing of an issue. Also, they may have someone helping them that has zero idea of what to do, so looking for the easiest route is their default. Even professionals ask colleagues for help.
@lookforthe1 - Which APX model do you have? Is it a handheld or mobile? Someone may have what you're looking for.
Hmm...perhaps adding particular radio code plugs for FRS/GMRS/MURS to the Wiki would be helpful for whomever in the future. I know I would prefer to talk with someone on GMRS using a Motorola versus a Baofeng, or Midland, but I cannot control that.
lookforthe1
thanks!! i have apx4000 uhf r2 split... doesnt really matter from what model bc i was going to drag drop it into my code plug... thats y i wasnt specific on the model and just said apx
lookforthe1
kind of are bc i couldof found that same info but again u never really answered the main request that i was positng about
ElroyJetson
Subpart B—Family Radio Service (FRS)​
I feel it necessary to caution you: Programming FRS transmit frequencies into your radio is illegal. Actually transmitting on them is an FCC violation.​
FCC Part 95 rules applicable to FRS and this discussion:​
§ 95.501 Scope.​
This subpart contains rules that apply only to the Family Radio Service (FRS).
§ 95.503 Definitions, FRS.​
Family Radio Service (FRS). A short-distance two-way voice communication service, with limited data applications, between low power hand-held radios, for facilitating individual, family, group, recreational and business activities.
FRS unit. A transceiver for use in the FRS.
§ 95.561 FRS transmitter certification.​
(a) Each FRS unit (a transmitter that operates or is intended to operate in the FRS) must be certficated for use in the FRS in accordance with this subpart and subpart J of part 2 of this chapter.
(b) A grant of equipment certification for the FRS will not be issued for any FRS transmitter type that fails to comply with all of the applicable rules in this subpart.
(c) A grant of equipment certification will not be issued for hand-held portable radio units capable of operating under both this subpart (FRS) and under any other subparts of this chapter (except part 15) if the application for such grant is filed on or after December 27, 2017.
§ 95.567 FRS transmit power.​
Each FRS transmitter type must be designed such that the effective radiated power (ERP) on channels 8 through 14 does not exceed 0.5 Watts and the ERP on channels 1 through 7 and 15 through 22 does not exceed 2.0 Watts.
§ 95.571 FRS emission types.​
Each FRS transmitter type must be designed such that it can transmit only the following emission types: F3E, G3E, F2D, and G2D.
§ 95.573 FRS authorized bandwidth.​
Each FRS transmitter type must be designed such that the occupied bandwidth does not exceed 12.5 kHz.
§ 95.587 FRS additional requirements.​
Each FRS transmitter type must be designed to meet the following additional requirements.
(a) Transmit frequency capability. FRS transmitter types must not be capable of transmitting on any frequency or channel other than those listed in § 95.563.
(b) Antenna. The antenna of each FRS transmitter type must meet the following requirements.
(1) The antenna must be a non-removable integral part of the FRS transmitter type.
(2) The gain of the antenna must not exceed that of a half-wave dipole antenna.
(3) The antenna must be designed such that the electric field of the emitted waves is vertically polarized when the unit is operated in the normal orientation.
ElroyJetson
I'm not the radio police but you should never act out of ignorance. Be aware of the rules, regulations, and laws, and then you can make an INFORMED decision as to whether or not violating them is justified when looking at the cost/benefit analysis. (Hint: Probably not.)
"But I didn't KNOW that was illegal!" doesn't fly with ANY judge.
Stupidity is probably incurable. But mere ignorance can be, with a little information.
jeepsandradios
East of the Mississippi
If you know how to use the CPS it is only a 5 minute job. Export, cut paste, import done. I am sure many would not share a codeplug on a public forum. And if you want to you can cut and paste directly into the codeplug.
WRTF671
I was wondering how long before the radio police were going to get involved with this post. Was way longer than I thought.
It's hardly being "the police" to remind someone that what they are asking for is most likely against forum policies and possibly against the law. I thought it was blatantly against policy to ask for/share software here, wouldn't sharing code plugs open up the same liabilities? If you program something into your radio you're not supposed to that's on you but if you use someone ELSE'S codeplug maliciously (even if you modified it) I see that as an implication of accessory. Is it a long shot that anything would happen? Yes. Do I think it's silly we're not supposed to use far superior equipment in certain frequency ranges even though it would actually be safer and have less risk of interference? Also yes. But does this mean I'll put my career on the line for someone to do something still considered illegal? Fat chance...
ElroyJetson
I disagree, there quite possibly could be liabilities involved with sharing codeplugs under certain circumstances. For example, if you were to share a codeplug that has public safety trunked information, you could conceivably bring trouble upon yourself when the person(s) you shared it with ended up unlawfully accessing a public safety system.
iowajm780
§ 95.501 Scope.​
Who cares. The chance the FCC police catches him is extremely low. He probably has a better chance winning the Powerball than getting caught by the feds.
WRTF671
I think that could extend to ANY scenario where someone TXs somewhere they're not supposed to. If they implicate you as the creator of the code plug is going to be YOUR burden to prove it was not possible to TX how they did on your code plug and that it was modified outside of your control. I don't see that ending well for anyone and at best case it's just a colossal waste of your time...
What he does with his own equipment and his own programming is not my concern, I just don't want to be an accessory. I don't think anyone on here that works in the industry does...
